Old Feb 10, 2020 | 12:51 PM
a1976's Avatar
a1976
Default Re: Clarify symptoms - RCM, CPS, SKREEM
Originally Posted by Kolme
Hello,
First to confirm it's likely the skreem module itself, unhook the battery to the vehicle for a few minutes and reconnect to reset the car. Attempt to turn over the vehicle. If it attempts to start, then suddenly shuts off 3 times and then does not attempt to turnover at all, then the Skreem module very well may be to blame.
The skreem module can be removed, however the car requires it to function, to my knowledge (granted I haven't had a xfire in 5 years). When I replaced mine, the dealership had to perform the repair as it requires recoding. Needswings, an aftermarket vendor, was supplying them at one point, however I'm afraid they have supply issues according to their website. Your best bet, if it is the skreem module, is a trip to chrysler.
Thank you, yes it is the SKREEM. The mechanic I took it to showed me the code B1000 and all keys are blocked in the SCREEM. He says the data in the module is corrupted and not fixable because the SCREEM comes with the data already programmed into it by the VIN, from the dealer.
