Old Feb 13, 2020 | 06:21 PM
  #1109 (permalink)
RL67037's Avatar
RL67037
Default Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Originally Posted by Iamian17
Hi,
Hopefully you check this and are able to respond. My key is not turning and my steering wheel is locked.
I am hearing I need to remove the steering wheel lock but I don’t know how to do that.
Most everything I see says I need to be able to turn the key but I can’t.
How do I get the old ignition out? Can I grind the little button down next to the steering wheel and pull it out?
Will that unlock the steering wheel?
I’m lost...and need help.
Have you read through the beginning of this thread. There are instructions that will hopefully answer most of your questions.
