Old Feb 14, 2020 | 09:48 AM
  #1124 (permalink)
electronwizard's Avatar
electronwizard
Default Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
its easy to get confused as there are different methods to fix this problem, some work on one crossfire and not another, I moved the steering wheel left to right to feel play and friction on the steering lock, my crossfire steering wheel had friction on the lock- toward turning left: so I held the wheel a little toward the right, then I tried to turn the key in a fast left to right motion, at that moment I vibrated the lock " housing " with an air chisel by the 10 mm bolt clamp on the lock housing , near the steering wheel, It would help if you had a second person to help to do this method, its worth a try so you don't have to do any grinding but it hasn't worked for everyone, If you try vibration of some sort I hope it works for you too, you might get lucky, not everyone has though,
