g wheels
Yeah mine has the same hole you describe. No plug or cover for it on mine either.
Hope you (or someone) can answer a question since you have had experience running the video / IR cable through that hole. I'm in the process of removing the inside panel(s) to get to the cable and connectors which are already through the hole. Is there any trouble getting to it when the panels come off? Any other tips are appreciated...
Taking the panels off is easy, putting the upper side panels back on is not. I would not take them off as the clips break trying to get them off and putting them on. I found it impossible to do and my good frien bluecoupe got into the tribune to complete the task.
I cannot remember if that hole actually does go into the trunk.
