Old Feb 25, 2020 | 11:41 PM
lotsofspareparts's Avatar
lotsofspareparts
Default Re: esp/bas light on
Originally Posted by rayludwiczak
04 coupe.. Noticed esp/bas light on. As advised started vehicle, turned steering wheel completely left then right. Shut vehicle off and restarted. Light out. Next time started noticed light on again and brake light lit. Repeated same procedure, bas/esp and brake light off. How do I resolve the recurring problem. Does not reset without repeating the procedure.
Does your brake pedal feel normal?
If the pedal is depressed to far, such as would be the case if you had air in your brake lines, the light will come on.
