esp/bas light on
Old Feb 25, 2020 | 04:40 PM
rayludwiczak's Avatar
Default esp/bas light on
04 coupe.. Noticed esp/bas light on. As advised started vehicle, turned steering wheel completely left then right. Shut vehicle off and restarted. Light out. Next time started noticed light on again and brake light lit. Repeated same procedure, bas/esp and brake light off. How do I resolve the recurring problem. Does not reset without repeating the procedure.
Old Feb 25, 2020 | 05:01 PM
Default Re: esp/bas light on
I'm sure it doesn't make any difference but I go to the right and then the left and then back to center before shutting it off and then restarting.
Old Feb 25, 2020 | 11:41 PM
lotsofspareparts's Avatar
Does your brake pedal feel normal?
If the pedal is depressed to far, such as would be the case if you had air in your brake lines, the light will come on.
CFbabe
45
Jun 15, 2019 11:37 AM
waldig
Aug 2, 2018 09:02 AM
AlexParra
Dec 9, 2013 02:10 AM
blackoutken
Jan 25, 2012 11:21 AM
MAXIMA
Jul 20, 2004 09:11 AM
