Old Feb 27, 2020 | 11:07 PM
onehundred80
Default Re: Cooling fans won't stop running with car turned off
If the engine is not warmed up past 200F, the fan wont run unless you turn the A/C on, then it should run at a low speed. If it simply wont run, it has to be:
Bad fan motor
Bad Fan controller module
Blown 50A fuse to controller
I dropped my crystal ball the other week so I cannot see what the problems are.
