Old Feb 28, 2020 | 05:28 PM
Johnny Versatile's Avatar
Johnny Versatile
Default Re: Exterior Garnish Trim failure with JB Weld
You will note the JB Weld did not fail as none of it is torn apart, it failed to adhere to the surfaces. I have to assume you fully cleaned all surfaces and scuffed the surfaces to be attached. Never skip either step. Never use quick cure. You should also clamp it. Now you know.
