Old Mar 2, 2020 | 02:20 AM
Ozzie007's Avatar
Ozzie007
Default No start cracks 3 times fuse 37 keeps blowing out
hi guys I've been following this forum room a long time and have had big help with all your write up.
for the past year I have not really able to drive my car I've had battery draining issues. And now does not start.
*the car has had a new battery installed less than 3 months old
* alternator replaced 10month old
*rcm module replace 1 month old
so before the car broken down when I was driving I kept getting the battery symbol flash was indicating the battery was low or not charging however when I push the car to accelerated above 50mph speed the light would go awayway it's only started happening when the the alternator was replaced I went back to the garage and they said to me they done test and alternator is working and charging battery and sent me away.
other issue I had was on very hot sunny days the car would not crack no sound nothing and would not start I was told that the rcm unit was gone so I was advised to change the rcm which I done.
the battery of the car still was draining so I thought maybe the battery is faulty installed a new battery after installing new battery is still draining so I've removed it one night and left it on the charger but by the time I got round to the reinstalling to car it was a few month after it was removed.
And after putting the battery back into the car it will not start I believe the skreem has gone as it cracked three times and I have to disconnect the battery and back again and cracks another 3 time.
I'm also having the fuse 37 keeps blowing every time I replace it straight away the manual say fuse 37 is for Circulating Air, Instrument Cluster, Radio Frequency Remote Control, Residual Engine Heat Utilization
also I don't know if this is related or if the car is like that when I try and start the car i get no instrument lights symbols on the dashboard they do not come on at all when trying to start the car.
I need your help to find a place in uk London area to fix the skreem module or maybe this another issue and also any of you guys have an idea why the fuse 37 keeps blowing straight away everytime the fuse is changed.
