Thread: 722.9
Old Mar 7, 2020 | 07:16 PM
Speedy4x4's Avatar
Speedy4x4
Default Re: 722.9
Originally Posted by joeyav
Hello all you Crossfire lovers!
Question for all you techies
Has anyone ever tried to install a 722.9 to replace the 722.6 transmission?
Personally I dont enjoy seeing the RPMs around 3000 at 75-80 when driving on the highway. Ive been spoiled by newer vehicles i guess. Unless of course there is something wrong with my transmission. Any positive feedback is always appreciated and the usual b... busting!
Are you running stock size tires ?
I run 285 /35 which are taller than the 255 /35, idbyou don't want the width you should be able to use 255/40 about the same as the 285 / 35, .9" taller at 26.9 vs 26", speedometer at 75 would be acouppe of mph off, but at the same gps speed would drop rpm down a pinch, also could get a srt ring and pinion going a 3.07 from a 3.27, or I there is a member that did make acouple 2.88 (I believe that was what it was)
75 mph, .83 5th gear, 26" tires, 3.27 ring gear
2631 rpm
Change tires to 26.9
2543 rpm
Add next the 3.07
2387 rpm
Use the 2.88 instead of the 3.07
2239 rpm
Takes down 392 rpm
if you happen to be able to use the 7 speed trans that with a .7267 gear then would be at 1961 rpm with tires and a 2.88 ring gear
All stock be 3,000 rpm you are doing 85.53 mph
