722.9
Old Mar 7, 2020 | 06:01 PM
joeyav's Avatar
Default 722.9
Hello all you Crossfire lovers!
Question for all you techies
Has anyone ever tried to install a 722.9 to replace the 722.6 transmission?
Personally I dont enjoy seeing the RPMs around 3000 at 75-80 when driving on the highway. Ive been spoiled by newer vehicles i guess. Unless of course there is something wrong with my transmission. Any positive feedback is always appreciated and the usual b... busting!
Old Mar 7, 2020 | 07:16 PM
Speedy4x4's Avatar
Default Re: 722.9
Are you running stock size tires ?
I run 285 /35 which are taller than the 255 /35, idbyou don't want the width you should be able to use 255/40 about the same as the 285 / 35, .9" taller at 26.9 vs 26", speedometer at 75 would be acouppe of mph off, but at the same gps speed would drop rpm down a pinch, also could get a srt ring and pinion going a 3.07 from a 3.27, or I there is a member that did make acouple 2.88 (I believe that was what it was)
75 mph, .83 5th gear, 26" tires, 3.27 ring gear
2631 rpm
Change tires to 26.9
2543 rpm
Add next the 3.07
2387 rpm
Use the 2.88 instead of the 3.07
2239 rpm
Takes down 392 rpm
if you happen to be able to use the 7 speed trans that with a .7267 gear then would be at 1961 rpm with tires and a 2.88 ring gear
All stock be 3,000 rpm you are doing 85.53 mph
Old Mar 7, 2020 | 07:49 PM
Speedy4x4's Avatar
Default Re: 722.9
And the 722.9 is a much larger transmission.
Old Mar 9, 2020 | 10:28 AM
joeyav's Avatar
Default Re: 722.9
Thank you Speedy4X4 I appreciate the feedback
Joe
Old Mar 9, 2020 | 12:38 PM
Speedy4x4's Avatar
Default Re: 722.9
Joe
Your welcome
KrzyFast
Apr 14, 2017 02:16 PM
ChuckNorris
Apr 16, 2012 12:09 AM
syfi
Jun 24, 2011 02:23 PM
32krazy!
Dec 5, 2010 10:54 AM
entropy
Nov 29, 2008 02:42 PM
