Old phart phred
Easy enough to swap coils, but none of them appears to be firing, haven't stuck my nose at the exhaust, or pulled a valve cover off to see if anythings moving or fueling. Starter sticking may make that simple to do.
fire triangle fuel air ignition
Did it suddenly lose power or did it just fade away?
Can you hear the fuel pump when you turn on the ignition to the position just before the start position with the doors closed and the window down?
