Old Mar 15, 2020 | 11:56 AM
KnightRyder_77's Avatar
KnightRyder_77
Banned
Default Re: Update on '04 Crossfire took it out today and need advice
Originally Posted by zip439
The trim has five metal clips on the top piece and I think three on each side piece. You use the tape only on the clips where they attach to the plastic trim. The way in which you state your question you may think the tape is applied around the plastic. Not true. Only place the tape on the metal clips and no need to remove any clip from the OEM tape unless it has become loose from the trim. It is obvious once the trim piece is removed. No prep required other than normal cleaning of the clip that will the get new tape (if tape is required).
Ok sounds simple enough. And yes I was asking if tape goes on to clips so now I know. Thank you for the advice and help. I will get to a body shop or NAPA and get some tape. My next thing will be to paint the trim. Any recommendations on what service to use for new windshield ?
