Re: Worlds Cheapest V8 Swap
remove your fuel regulator/filter ,,,install a adj regulator (don't forget a return line) set fuel pressure to 60 to 65. you may need a srt or a V8 fuel pump. mine was dying off above 4000 rpm pump and solved it then reg went in to lower AFR.
