Thread: FSS wont reset
Old Mar 24, 2020 | 09:56 AM
dedwards0323
Default Re: UPDATE on FSS reset
Originally Posted by old fart
I was asked to post some pics of what my FSS shows now, that I reset it, so here goes. The pic with the oil can in the tripmeter and the clock in the odometer shows up about 10 secs after turning ignition to run and lasts about 10 seconds before returning to mileage readings. It does not show up if I go straight to start. When I first reset the FSS, it did show 7000 miles, but since then has gone to the oil can and the clock. I can't find anything on this scenario. Bet someone out there knows
shows up only for a few seconds if key left in run position but not having been started
Normal view
The Oil Level & Clock Icons you see are associated with the onboard electronic oil level sensing system in the car. Chances are the oil level sensor has gone bad. If your oil level shows good on the dipstick, don't worry about it. See attached pages out of Owners Manual. Your FSS probably reset properly if you remember seeing the 7000 mileage indication. Electronics on these cars are a PITA!
If you haven't already, go to onehundred80's Crossfire Library thread & download a copy of the Service Manual for these cars. The 2005 version gets you info for the Coupe & Roadster; both NA & SRT-6 models.
File Type: pdf
