Old Mar 26, 2020 | 01:59 PM
GraphiteGhost
Default Re: Replcing Engine wiring harness
Originally Posted by NCSU
I have a 2006 base model 6 speed manual Crossfire.
Squirrels made a nest in the engine compartment.
They made a feast of my wiring harness's under the hood.
Car runs fine but the check engine light is on so I can't get the car inspected to renew my lic. plate.
Has anyone had experience in changing the wiring harness's under the hood?
There seem to be at least two major wiring harness's.
Does anyone know how many there are?
Do you know where I could find a wiring diagram?
Any help or ideas would be appreciated.
Thanks in advance for your help.
Mark
Dave has a great idea, in the service manual there is (if I remember correctly) a pictorial drawing showing the under hood harness. The actual schematics in the manual is more of a block diagram that might not be what your looking for. I think (heavily on the think part) what you should look for in the manual is the section showing components locations. I hope you find what and where the actual harness locations are but think fixing the place where the rodents chewed might be a 'lesser-of-2-evils'. Might be all you need. If that doesn't work, then at least you can further troubleshoot here! Good luck!
