Old Apr 15, 2020 | 05:32 PM
amx1397
Default Re: Axle Swap from a Standard Crossfire to SRT6
the limited axles 2005 and up (one piece axle) are the same,,,kinda 2005 has same P/N 2007and up is a larger but hollow axleand stronger, the srt6 has a 3.07 diff the limited has a 3.27 the tcu has to be set up to the car(srt or limited) I can supply you a tcu for a srt6 set up for the 3.27 diff or you can just use the diff from the srt6 with the axles from the limited . the yoke is different on the srt and the limited. as stock they do not interchange yet the axles do.
https://www.crossfireforum.org/forum...ferential.html
https://www.crossfireforum.org/forum...tune-info.html
