ecuserwis
Hello
in Europe there exist a real SKREEM emulator for a long time, without any restrictions, it works like the original in terms of unlocking the immobilizer, the SKREEMULATOR pretends to be every of the key implemented in the immo 0 to 7 , with the right numbers of starts as programmed in the MB(Yes MB , it no mistake) factory.
For add EMULATOR don't need change any one byte in PCM :
www.instagram.com/p/B_W6MWehLPq/ ... solution it's not plug and play.
B.R. from Poland
Hello,
nice device and it seems like it woks similar to the first version of my skreemulator. With the difference that you probably managed to create new valid codes from two valid codes. I haven't got that right yet.
But this also means that your system has also the limitation in the maximum number of codes.
My new solution would no longer have this limitation.
And I'm from Europe (Germany) and have never heard about your solution...
