Old May 9, 2020 | 11:36 AM
WD40's Avatar
WD40
Default Re: factory windblocker?
Yeah, ONLY 2/1000ths of an inch? Hardly a difference is right UNLESS the guy holding the drill wiggles like he11 while holding the running drill! Still, I bet the 'serts' would be real tight! Just do not use a really long drill bit, maybe??? Never can be too careful with what is behind it (as a GENERAL rule).
True. I've used the rubber tubing trick for 30 years. Using the proper diameter of small rubber tubing (or silicone tubing, if you have a bunch left-over from that craze!), cut the proper length of tubing so it slides over the drill bit leaving only as much of the drill bit visible as you wish to drill into your 'object'.
