Old May 11, 2020 | 10:56 AM
HazMatt's Avatar
HazMatt
Default Re: No Crank, No Start - Tried RCM with no luck
Originally Posted by ZERACER
It can also be a bad relay or the new solder did not hold up, send it to TJ.
yes, I believe I've located the problem as a bad contact on a relay. It was probably due to the original soldering issue but you can see blackening on it. I'm going to try and clean it up and give it another shot otherwise I'll need to replace it. I'll check back in with the results. Thank you everyone!
