Old May 12, 2020 | 01:21 AM
matabufalez's Avatar
matabufalez
Default Re: Transmision problem
Originally Posted by KnightRyder_77
I know this a old thread but I swear this sounds like my problem. With out repeating all thats been said. My car acts just like the drive has come apart. Shifting was fine and all of sudden no more movement except coasting. Car shift fine. When clutch is pushed in. Just does not move. I already bled all brake lines and slave cylinder and still save issue..also if car is in gear it will not roll freely. I will keep you updated as I plan to work on it this week. Miss my girl
Hello,
If it has my problema, It is very simply to check.
Just elevate one side and start the car. Put any gear and go under the car, you have to check if the gearbox output is moving and if is attached correctly to the output flange.
Mine esa repaired and after 5000 miles It is working fine
Check It! Spare esa 150$ at MB dealer
