Old May 12, 2020 | 10:01 AM
Speedy4x4's Avatar
Speedy4x4
Default Re: Transmision problem
So when your car is parked with the engine running or not running, you can shift through all 6 gears and reverse fine?
And acts like the clutch pedal is stuck tonthe floor ?
or acts like there is no driveshaft connected ?
you say if it is in gear that it does not roll freely, if you are trying to move it when in gear, pop the hood and you should see the engine belt turning.
if in gear and tires are rolling, the engine will turn with a manual transmission
With, say drivers or passengers side in the air and rear tire off of the ground, since we have open differentials you can try to turn the rear tire, even in 6th gear you should bot be able to turn the tire, take out of gear, make sure the wheels on the opposite side are blocked so no chance of forward or rearward movement, take out of gear and see if spins freely or of there is any difference.
