Old May 19, 2020 | 08:58 AM
  #342 (permalink)
GraphiteGhost
Default Re: p0410 secondary air injection system malfunction solution?
Originally Posted by jamesmcaleer
Hi there, you can do that or you could disconnect the wiring plug by just pulling the supply off where it goes in the pump
Either will be fine
IF you disconnect that pump, you MIGHT get a bunch of codes and CEL, as the pump is for the cats and the emissions!
