Old May 31, 2020 | 08:05 AM
  #348 (permalink)
zip439's Avatar
zip439
Default Re: p0410 secondary air injection system malfunction solution?
Originally Posted by jamesmcaleer
If you remove the air filter housing it's located at the top and the front of the engine, if it's not there could it have been removed by previous owner and not replaced, just a thought if you'd possibly just bought the car
If you google up secondary air pump for crossfire, that'll show what it looks like,
I'm not trying to be sarcastic, just trying to help in case you're not sure what it looks like.
Regards
Teak
to Ed's SRT6
That info is incorrect. On a SRT6 the air pump is located on the drivers side on the fender aft of the radiator. The fuse he speaks of is located on top of the Relay Control Module (RCM) which is located inside the large black plastic box on the passenger side alongside the cars battery. The fuse is the large orange one that says 40 on it. Perhaps you should gives more information. It will helps us; help you. A picture of the RCM is in post #329 of this thread.
