Old Jun 1, 2020 | 03:13 PM
  #355 (permalink)
ssl92677's Avatar
ssl92677
Default Re: p0410 secondary air injection system malfunction solution?
Originally Posted by jamesmcaleer
I had the pump disconnected for about a month, i just pulled the wire off the pump with no ill effects, while I was waiting on the new arriving, I was informed the pump only works on start up for about 30 seconds, as you know my car is non SRT but it ran fine till I got the new one.
Regards
Teak
My understanding is the pump runs on startup for a short period for initial fuel/air mixture adjustment until CATS attain temperature and the ECU takes over. My experience was the P410 code was generated because although the pump ran correctly at startup, the dirty/corroded contacts on the RCM relay caused the relay to intermittently chatter (make/break) while driving. It took awhile but I finally made this observation when came to a stop at a light one day and I heared the high-pitched whine coming from the the air pump again uneccessarily. Fortunately, replacing the RCM solved the issue for me without needing to replace/rebuild the air pump.
