Old Jun 7, 2020 | 06:38 PM
onehundred80
Default Re: TPMS replacement ?
Don't know why it wouldn't. Video shows the Autel MaxiTPMS Pad reading an existing wheel sensor & then copying that information to a new Autel MX-sensor. If it can scan an existing wheel sensor,which could be any version, seems to me it could copy that information to any other suitable sensor. My original feedback when maggy55 asked if the Autel MX-dual frequency sensor would work, was it required an Autel TPMS tool. Sounds like someone needs to execute a "test case".
I have an Autel 501 TPMS scanner tool & it reads the Crossfire OEM sensors, which are sourced from Schrader. And my scanner tool has the capability to clone new sensors by inserting them into a slot that exists at the top of the tool. You then select which wheel sensor you want to clone.
I found on another ad that it was good for the OEM and Autel sensors only. True or not true? Who knows.
