Old Jun 24, 2020 | 02:15 AM
GraphiteGhost
Default Re: Help !!! Cooling Fan and A/C issues
Originally Posted by Sussudio
Appreciate the info. Thanks again
There is a critical observation MISSING in 180's reply. As amended: "Putting a voltmeter on the studs holding down the fuse should give you a 12V reading IF that fuse is blown"! You cannot read a voltage across a fuse that isn't blown (just like testing a wire that is still connected between the test probes of a voltmeter).
