GraphiteGhost
There is a critical observation MISSING in 180's reply. As amended: "Putting a voltmeter on the studs holding down the fuse should give you a 12V reading
IF that fuse is blown"! You cannot read a voltage across a fuse that isn't blown (just like testing a wire that is still connected between the test probes of a voltmeter).
180 said check the studs, he didn't say BETWEEN the studs. Both studs should read 12v if the fuse is good, only one if it is blown.
You two pick at each other too much. Don't make me have to come up there.
