Old Jun 28, 2020 | 06:37 PM
onehundred80
Default Re: REST Button Automatically Turning On....
Originally Posted by Curteis
After I turn off my vehicle, without being depressed, my REST button turns on- recycling the air inside, and does not turn off by depressing/pushing the button. Unlatched negative terminal battery line, waited about 15-20minutes, reconnected, and same result proceeded. Many assistance would be greatly appreciated. Possibly a fuse location so I can keep my battery connected without being drained from REST fan blower motor running while my engine isn't engaged.
Whatever the cause the REST feature should automatically switch OFF when the cars brain senses that the battery has lost enough power for it to continue any longer. The REST heat feature runs a pump and the blower motor, if it was just the blower it would soon blow cold air. On AC it blows until the heat exchanger is warmer, the air also dries the heat exchanger and prevents mildew and bacteria growth on it
Good luck.
