Old Jun 30, 2020 | 07:55 PM
onehundred80
Default Re: Circulating fan won’t stop running....
Originally Posted by JoeO
I am a 1 year owner of a 2004 automatic and have come upon my first problem after a 45 minute drive. After I turned the key off I discovered the circulating fan was still running. Checked the fuse which was ok, and replaced it with the spare to make sure. Still running.
Nothing else seemed out of whack, so I disconnected the negative terminal. And here I sit with my jaw on 8 knuckles.
surly, this has happened before......a cold One for the answer !
Is the REST button depressed? If so the fan will run until the brain determines the battery has lost enough power, or you hit the button again. In AC mode it's used by some to dry the heat exchanger to prevent bacteria growing.
