tadmaz
I am checking voltage with a multimeter directly at the connector. Ground wire to a ground source works. Is there a way to remove the wire from the connector?
Use a pin or darning needle and push it through the insulation and touch the wires inside, small pin will let the wire close up the hole but insulate with tape anyway.
