Old Jul 12, 2020 | 02:47 PM
onehundred80
Default Re: OEM Amplifier Location With Pics
Originally Posted by 208james@gmail.com
Hi I pulled my amplifier forward and noticed some oil at the bottom of the metal mounting plate which may have always been there. I don't believe amplifiers have anything to do with oil. I cleaned it from the wire harness Ext.and hopefully that will be the end of it. There is what appears to be an open vent tube into this area and assumed it was probably to add air for cooling. Any thoughts are appreciated . Thanks
The oil wicks up a wire from the oil level sensor which is on the passenger side of the upper sump.
It does not get better so you have to get the leak fixed.
