Old Jul 15, 2020 | 09:58 AM
208james@gmail.com's Avatar
208james@gmail.com
Default Re: OEM Amplifier Location With Pics
Did you check the fuse?The lighter and glove box light are on the same fuse and the ignition has to be on for either to work. You can access the back of the lighter by removing the console kick panel in the passenger foot well, a bit tight to access but you should be able to feel if the connector is disconnected
