Re: OEM Amplifier Location With Pics
Good info, Glove box light is now working and the last thing I need is to fix the cig lighter simply for the power source. I may even install the dual USB I saw someone did but I still need to know what is gong on with the lighter. Are they known to go bad? Maybe it is unpluged, i will check. I also read there is a light for the ashtray but I dont see it either.
I also have code B48 passenger seat occupant airbag mat and I see it is located by the amp, could it be that it was damaged by the water also? If so, what is the fix? Code mentioned there was a bad connection is why i ask.
