Old Jul 18, 2020 | 02:44 PM
pizzaguy
Default Re: Top switch red light on
Originally Posted by crevine1
Okay so would the diagnosis be the same if I said, when turning the "D" ring the windows lower, then the red light on the switch illuminates, pushing the "lower top" side of the button results in "beep!" and multiple attempts results in beep, beep, beep, etc....
I already checked the other micro switches, fuse, not sure where the relay is? The pump was strong up until this moment? I'm hoping, to spite the work, this will solve the problem. If nothing else, it's one hell of an education. : :-)
This can be the divider switch or the switch George mentioned above. (In fact, it can be the trunk latch switch or electric lock, but those failures are quite rare.)
The light is supposed to come on when you unlatch the D handle, the fact you get a beep tells us the TCM is not ready to move the top. Again, if the divider OR top open switch is not closing, you get this indication.
