Old Jul 27, 2020 | 04:45 PM
  #40 (permalink)
pizzaguy
Default Re: Crankshaft Position Sensor or Camshaft Position Sensor
Originally Posted by phil alvirez
and if the engine stops and we want to learn if it is 1 or the other that is failing, could we use a creader?
i have the 319. could it do?
if we carry the spares and a reader we could at least attempt to replace the culprit.
otherwise even if we carry the spares we still will be grounded.
IF the check engine light comes on, then yes. The code(s) will tell you which is in trouble.
But some times, the Crank sensor (and mabye the cam) will fail in such a way that the check engine light does not come on, no code is set.
I do not know why this is, but in some cases, the ECU does not appear to know what it is missing.
