Old Jul 28, 2020 | 04:16 PM
GraphiteGhost
Default re: More Airbag Module Issues
Originally Posted by darkeid
Thanks for the heads up. I will drive to the other private garage and have it reset again before sending both of em to where that guy suggested.
Not quite sure what your saying. Did you install the new used part yet? IF the numbers are the same and all that is needed is resetting the light, then research the forum here for what OBD readers can reset the light, and do it yourself. This will probably save you a lot of money AND you'll have a diagnostic tool to help you from now on. REMEMBER TO REMOVE THE NEG CABLE FROM THE BATTERY AND WAIT THREE TO FIVE MINUTES BEFORE PULLING/CONNECTING ANY PLUGS! Good luck!
