Re: Starting problems
I removed the negative battery cable before I pulled the number nine fuse. Then I reattached the battery cable and tried to start the car. It did not start.
The siren is not working. Based on what you’re saying it sounds like I should try to fix the siren to see if that also fixes my starting problem. Does that make sense? Should I do that before following the instructions pizza guy gave me?
