Old Aug 9, 2020 | 04:49 PM
Natesnyder's Avatar
Natesnyder
Default Re: OEM Amplifier Location With Pics
Originally Posted by ACRucrazy
And the shortest installment of my stereo how to with pics threads. LOL.
Step 1. Remove the passengers floor mat and peel back the carpet. Start at the very top and pull straight back. Its quite easy to do.
Attachment 48491
Step 2. Remove the big styrofoam cover, it just pulls right out. Then remove the 3 plastic nuts that holds the metal bracket in place. These are 10mm and located one in the top center and one in each bottom corner.
Attachment 48492
Step 3. With the mounting plate unbolted just tilt it back towards you, away from the firewall and let it rest on the carpet pad. There is plenty of slack on all the wiring. The big silver box on the your right hand side is the amplifier. There are 2 plugs on the back/bottom side of the amp with locking clips facing the floor. These plugs are very tight, the 12 pin plug is the on the right contains the signal input from the stereo and the ground wires for the amp. The 18 pin plug on your left side of the amp contains the speaker level output, 12 volt battery supply, a VSS wire and a convertable top status if its a roadster to improve the sound with the top down.
Attachment 48493
Notice: The passenger seat occupant airbag module and other wiring located in this area. It is important to be aware of these modules and wires.
Attachment 48494
Here is a diagram
Attachment 48495
this is old but hopefully someone can help. I just ordered new door and rear speakers as well as a dual 12' box that comes with an amp and everything. I'm planning on using both amps if that's possible? How would I wire the head unit to do so?
