onehundred80
If you had used the SEARCH feature you would have found that the IC pump was generally the problem. Get the Bosch pump with the part number that ends in 010, if you have the pump that ends on 002 the rotor inside disintegrates.
There is a PDF on how to replace the pump and you can search for that easily.
Thanks
ok where would the part number be located on the pump
