Old Aug 22, 2020 | 11:49 AM
onehundred80
Default Re: Help with brake light switch
Originally Posted by Alwyn
Hello All
hope someone can help with this one ,I am working on a 2005 crossfire
it has many faults
main concern is brake light don't work.i have dropped lower panel
to find switch has already been replaced
also only two wires going to it .the switch is in N/C position
so presume cuts a signal to engine ECU
can not find another plug anywhere near the switch that will
fit .even though the switch has an extra 5 terminals with nothing going to them
as no brake light car will not come out of park
Is the brake switch built into the brake servo
as they are on Mercedes ml.s
Not coming out of PARK and no brake light are two different faults.
Look at the wiring diagram in the Service Manual which you can download from the thread called Documentation or from the link in my signature.
You can use a pen in the gear shift to get the car out of PARK as shown in the Owners Manual can also be downloaded from the above noted thread.
