Bypass relay control Module
Aug 31, 2020 | 01:01 PM
permalink
Alwyn
Aug 2020
Alicante
3rd relay coil is open circuit
Circle denotes coil for relay Number 3 open circuit Test with multi meter all should be the same reading
The two arrow show input and out put of relay
I drilled hole in cover
Then wired in external relay holder
Bypassed As didn't have a RCM in back of van Not pretty but it works Use a normal N/o Relay Contacts 85 and 86 go to the two pins i circled Contacts 87 and 30 go to the input and out put Arrowed Resistor built into board so can use a normal relay
M4rCu5
Alwyn
View Public Profile
Send a private message to Alwyn
Find all posts by Alwyn
