Bypass relay control Module
Old Sep 12, 2020 | 12:18 PM
Default Re: Bypass relay control Module
Originally Posted by Cobrasrt8
Thanks, yes I got it. Unfortunately I confirmed it's not the rcm that's the problem.
That is an obsolete photo, there is an updated one around.
Old Sep 12, 2020 | 12:39 PM
onehundred80, haven't heard from you in awhile, I was concerned.
Old Sep 12, 2020 | 04:47 PM
Thanks for the concern, I am OK and have basically given up answering most queries, it is time for the younger crowd to step up to the plate.
Old Sep 12, 2020 | 05:38 PM
Agreed, most of them don't listen anyway.
Old Sep 12, 2020 | 08:29 PM
Cobrasrt8's Avatar
Originally Posted by tighed1
The traction control relay can affect the speedometer and BAS/ESP.
The relay with the burnt contacts is the air pump relay. Common problem.
Both can be fixed with relay replacement. That's what I do.
Email tighed1@hotmail.com if you would like to get your RCM refurbished.
Thanks tighed I think I I'll send you the spare rcm to repair for me as a backup. Do you have any idea where I can go from here to fix my issue? I held the traction relay open and started the car and the bas,esp,brake, and abs lights all came on. But also I could not get it out of park so I ruled the relay out since when the problem happens the shifter is not affected. I also swapped out the TCM without success.
Old Sep 12, 2020 | 08:36 PM
Cobrasrt8's Avatar
mcjack301
Oct 1, 2020 05:55 PM
Yanksmell
Mar 17, 2017 11:23 PM
Jonathan82
U.K.
Aug 19, 2010 05:40 PM
pt0001
Feb 5, 2008 11:04 PM
Louie K
Aug 11, 2007 08:25 AM
