Old Sep 7, 2020 | 12:59 PM
GraphiteGhost
Default Re: Bypass relay control Module
Originally Posted by Alwyn
Bypassed As didn't have a RCM in back of van Not pretty but it works Use a normal N/o Relay Contacts 85 and 86 go to the two pins i circled Contacts 87 and 30 go to the input and out put Arrowed Resistor built into board so can use a normal relay
Alwyn, just a suggestion, cap off (or tape/clip) the black bare wire. It might be hot and if so while taking it out/testing, that lead may hit a ground. Don't know how it is wired, but if you test it not running or key 'on' (to a ground point) it might be hot.
