Car not starting - fuel pump relay
Hi all from Sydney, Australia.
My 2004 convertible refuses to start - no early warning given.
Engine cranks over, changed both crankshaft and camshaft sensors and cleaned the RCM and still no joy.
I did notice that the fuel pump relay does not open (or is it close) when trying to start - the other relays are OK.
Question is: are all the relays on the board identical - can I swap them over to see if the fuel relay is the problem?
I now also get a clicking sound when I try to start the car and the gear shifter is locked in park (I can unlock it with a screwdriver).
All helpful suggestions will be appreciated.
Thanks
Ron
