Old Sep 8, 2020 | 08:30 PM
GraphiteGhost
Default Re: Car not starting - fuel pump relay
Originally Posted by bluey42
Hi all from Sydney, Australia.
My 2004 convertible refuses to start - no early warning given.
Engine cranks over, changed both crankshaft and camshaft sensors and cleaned the RCM and still no joy.
I did notice that the fuel pump relay does not open (or is it close) when trying to start - the other relays are OK.
Question is: are all the relays on the board identical - can I swap them over to see if the fuel relay is the problem?
I now also get a clicking sound when I try to start the car and the gear shifter is locked in park (I can unlock it with a screwdriver).
All helpful suggestions will be appreciated.
Thanks
Ron
Originally Posted by Fla_Xfire_SRT
The RCM repair is not going to address the locked in park issue. There are many threads here on the forum dealing with that issue however, as well as videos on You..tube..showing how to remove the trim in case you need to change out your shift module...Good luck.
It might be an issue with a relay on the RCM (the clicking during starting) IF the battery was drained to the extent of it not being able to start the car regardless of the relay in the RCM.
Oh, YES, all 5 relays are the exact same relay in different positions.
