Old Sep 12, 2020 | 01:12 AM
tighed1's Avatar
tighed1
Default Re: Bypass relay control Module
Originally Posted by Cobrasrt8
Can someone please tell me what relay is what in the rcm. I have the intermittent problem with loosing the speedometer and the bas/abs, esp, and brake lights coming on. I've replaced the conductor plate twice, first with a rock Auto and then with one from needs wings without success. I've also replaced the RCM about 2 years ago with one from Rock Auto as well. I'm using alldata schematics but I don't think it's correct for the relay positions. I have 2 rcms and both relays at the very end look burnt to me and do not turn on when the key is in the run position.
The traction control relay can affect the speedometer and BAS/ESP.
The relay with the burnt contacts is the air pump relay. Common problem.
Both can be fixed with relay replacement. That's what I do.
Email tighed1@hotmail.com if you would like to get your RCM refurbished.
