Thread: Battery Drain
Old Sep 12, 2020 | 03:01 PM
  #48 (permalink)
king happy's Avatar
king happy
Default Re: Battery Drain
ok , pulled the fuse holder . unhooked the wire that has 2 reds and a black . It appears that it is the power wire coming from the 200a fuse . When unhooked the big red wires on the stud to the left and the wire with 3 reds that was on the same stud showed 0 volts . The wire with 2 reds and 1 black that i pulled showed voltage . So hooked it back up and pulled the terminal with the 3 wires and the discharge stopped . touched it to the terminal , small spark and draw comes back . It is diffidently this terminal with the three wires . Anyone know where they go ? this is going to be tough .
This is the problem child
