Originally Posted by Sennaspirit
Ben, Thanks for posting this up again. I think I mentioned that I have the howl too as mentioned by 13dog previously. Mine is consistently heard at 80 mph (give or take +/- 3 mph). It more like a humm, but it only is apparent at that speed and goes away if I'm over or under that speed.
Question, is it really an issue worth getting the rear changed? Is it damaging the car?
Did your repair fix the problem?
Thanks,
SS
You’re welcome.
Yes, my noise was a humming noise, much like what you hear from snow or truck tires. As far as getting it fixed, the noise drove me nuts nor is it normal, the gears in the rear end are not right and will only get worse over time.
Yes, the rear end swap fixed the problem.
The mileage on my car was 14k when I had mine fixed.
Good luck to all with the problem…
