Originally Posted by ben47
You’re welcome.
Yes, my noise was a humming noise, much like what you hear from snow or truck tires. As far as getting it fixed, the noise drove me nuts nor is it normal, the gears in the rear end are not right and will only get worse over time.
Yes, the rear end swap fixed the problem.
The mileage on my car was 14k when I had mine fixed.
Good luck to all with the problem…
I have that same noise and thought it was the tires. It sounds like a pick up truck with big tires on it or a car with snow tires. I was going to go out tonight and put a different set of tires/rims on it. Maybe I should go to the dealership and see what they say. It vibrates the interior at around 40.
